gday ive done a search on this and havent found much ive bought a boost and egt gauges from flebay and im wondering where to plumb them in i know egt as close to the turbo as posible so as my dump pipe is cast i was thinking can i drill and tap it or should i jus weld the bush into the exhaust just below the flange..
as for the boost gauge were do i hook it up to some say the intake some say remove the safty valve and use a addapter how did you guys plumb it in and where
cheers kezz
cheers kezz
