Hi folks
Just a quick question, is it OK to connect a boost gauge by putting a "T" piece in the rubber tube between the bottom of the turbo and the waste gate? Seems to be the simplest!!!
yes, it is possible, but for a true reading you need to tap into teh manifold. the easiest place i can see is the L-bend that connects to the 2" tube coming form the turbo, with 4 bolts into the intake manifold.
Had a quick look and you are spot on, drill and tap the inlet to the manafold just to the right of the relief valve on the 90 deg bend is simple as. Thanks again. :grin::grin:
