Hi all, big ask here. I need to check my boost levels as my gu is overboosting as per the gauge and I'm asking if someone in brissy has a manual boost gauge I could use for a test. I will travel and it will only take 5 minutes.
Thanks
Troy
Hi mate ,
Im in nsw so cant really help u buddy on lending the gauge but just remove the waste gate shaft circlip on the turbo and make sure the shaft moves freely when you pull on it with a pair of pliers, if it is over boosting it could be because the waste gate controller is damaged and not releving. cheers mate.
