You can add say a 1mm or so shim, I strongly advise against adding multiple shims to reduce fuelling on a large scale, this does affect timing curves.
As does when playing with the fuel screw, but also, the fuel screw will affect things from idle all the way through, not a smart thing to do.
You mention Redarc gauges, hmmm.
Just a observation, my eBoost street boost readout is far from accurate, the Autometer gauge and the dyno which uses a transducer are within a psi or so of each other.
Few gauges that give weird readings on our dyno, Redarc and SAAS, about on a par, is another with flashing ligths and **** that I cant remember the name of that also give weird readngs.
