1841 - 1841 of 1841 Posts
SUI GENERIS UTE
GQ Ute 1990 Silvertop
You will find T5 is better in 6060 or 5052/1 if you can get it.They are a bit more flexible and not prone to fatigue as much. i used 4000 series cast wire to weld the joints for the same reason i dont want to have fatigue either side of the weld joint.
But all your 2mm pipe bends will be 6061 T6 so you might as well use 6061 tube i didn't but i used those intercooler bends off ebay.
