hey everyone , might be a stupid Q?
changing rotors and pads next week , just curious ? when you do your rotors do you need to replace your bearings ? or is it just a case of pulling the old ones off ? and has nothing to do with the bearings?buying the rotors and pads on thurs should i get the bearings ? 98trb dies 2.8.
Long as the wheel bearings are ok. Just repack them. I'd only replace em if I had to. Also te use of a think it's a 54mm hub so key will make ur life a lot easier.
So you need pads,rotors and hub seals. Ad some good wheel bearing grease.
Also the bearings don't really have anything to do with the rotor apart from hold the hub onto the stub axle. Apart from that rotors on outside of hub bearings are on the inside. Make sure your bearings are loaded correcty.
thanks benno , will do ! thanks for the advice , will let ya know how it does :)
