Hi guys,
this is going to be a big luck if someone can actually diagnose this but I have to try. I am not even sure I can describe this properly with my limited english but it's worth a shot.
For some time now I'm having an intermittent issue with my 2.8 GU. When I'm driving about 60km/h I suddenly hear this noise that is accompanied with slight vibrations of the whole car. Usually this happens when I hit a tiny bump, the jump sets it off.
The sound is then present for few second or minutes and then suddenly disappears. The best way to describe the sound is it sounds like the aboriginal bullroarer but deeper.
The sound sounds and feels like it has to do with something that is rotating...so wheels or drive shaft or something like that... but I might be wrong. The sound is present even if I disengage the clutch. It's there even when I'm slowing down and then when I'm really slow it disappears.
When I was driving near walls I could hear the sound and I have also heard some metal rattling. Later I have seen that one of the sway bar links was loose so I have replaced both links but unfortunately that didn't fix the problem.
So did anyone have a similar issue or could give me some idea what the problem could be?
thanks
t.
thanks
t.
