Hi guys,
I recently purchased a premier winch and went to put in in a nissan winch bar, however when put the "right way up", with the cable spooling out from the bottom of the winch i.e closest to the ground, the cable runs over a metal support bracket on the winch bar - not good for winching over that.
I can flip the winch so it is upside down however the cable then spools from the top of the winch. The instructions that came the winch state that this is incorrect, and it should spool from the bottom (winding back under the drum), not over the top.
My question, is this ok to have the winch cable spooling back over the top of the winch when the winch has been turned upside down? Please note, I am not talking about removing all the cable and winding back on in reverse, just flipping the winch upside down.
Thanks in advance guys
Regards
Craig
Regards
Craig
