1 - 7 of 7 Posts
doubt it very much so.
you handy with a soldiering iron and heat shrink or tape??
not hard to extend a loom a tad to make it work. just cut one wire at a time and reconnect. tape each joint individually then tape it all up to look like factory and bobs your uncle.
You can fit it upside down as long as the air flows through it the right way. Normally they have an arrow showing the airflow direction. As long as it's facing the the engine, you should be fine.
I cant see any pproblems mounting it upside down as it's just a sensor. Like the bloke above me said as long as it's facing the right way.
Nissan GQ
I'm the the lads above me, there should be no reason why it wont work upside down. It measures airflow not fluid so unless the 2 that said no can add a reason. I'd go for it.
No, you cant.
Your engine engine will be confused and think the air is upside down - this is bad :rolleyes:
1 - 7 of 7 Posts
