Hi everyone I'd love some input on where to look next to fix my 2010 crd St auto.about 6 months ago I was driving and I heard a loud pop like an intercooler pipe blowing off. I pulled over checked it all looked good but since then it has run very slugish and blowing smoke and hard to start and had an engine knock which got louded and louder, eventually got so bad was struggling to get over 40kmph 700 plus egts and heaps of black smoke and impossible to start without start ya bastardand throw this code P0341 Camshaft position sensor. I changed a few parts, glow plugs fuel pressure relief valve fuel and air filter. Nothing made a difference so I booked it into a diesel tuner. They changed the injectors and injection pump genuine fuel filter and put a hpd boost controller in. That made it heaps better to drive fixed the fuel and boost issue for sure and low stable egts however did nothing for my load engine knock and slugish motor.i left there with all the same codes and out of pocket 5k and no money left for more repairs. It's also got a manifold leak I can hear when it's cold.the mechanic at doctor diesel said the engine knock sounded like the possible can timing jumped half a tooth in his words. Not timing chain as it wasn't a sound from the bottom of the engine.
So I've done about 1000km since getting it back mind you it sat at the panel beaters for about 6 weeks I made sure I sent it almost empty and put a full tank when I got it back. Last night filled up at BP and 30km down the road the car just started power down then shut off and I can't start it. It doesn't even crank over so I left the car on the side of the road. Not sure if the car shutting off related to the earlier problems or bad fuel or som sort of relay. I check a few fuses that I thought msy be relavent and I also took a fuel sample from the primer and it's looks clean to me. Not sure what to do next other that check more fuses and relays. I've included a video of someone else's car I got off this page and mine is doing the exact same thing when I try and start it. I haven't been able to check for new codes yet but I will tonight and hopefully try a few ideas.
