1 - 20 of 24 Posts
Rogue
nissan gu patrol
Hi all,
I went to Burson Autoparts to get stuff for a service. When I got home I realized that the oil they gave me was a diesel 15W-30. Last few times I have got oil it was a standard petrol oil which is weird but I do believe is the correct oil.
Can I use the diesel oil?
Castrol recommend Magnatec Diesel 15W-40 or Magnatec 10W-40 at their own NetLube site.
Run your vehicle details through the tool here.
Rogue
nissan gu patrol
Its in now so bugger it. If it dies its just another reason for an engine conversion! :D
As far as i know the ZD30 requires a semi-synthic grade of engine oil. Thats what i was told when buying oil for my 3.0 Navara Ute
You may want to check what really went into that motor. I can see no reference at all to a Castrol GTX Diesel 15W-30 there is however a 15-40. It appears to be a dino oil as opposed to the semi-synth Magnatec 10W-40.
I believe that you won't have any problems running it for this single service interval. Get back to the mob that recommended it to you and see what they reckon.
Oils
Well, my drivers handbook for my 2005 GUIV recommends 5W-30 for both petrol and diesel.(CF for diesels)
Why not see what your drivers Handbook recommends and use that?
castrol recommends magnatech proffesional 5W40 which you can't get through the retailshops.
magnatech 10W40 comes close to it.
if your real fussy you can use the more exp. castrol edge sport 5W30 or the edge 0W40..
these modern diesels don't need the diesel oil anymore and with some of them you need to be really carefull what you put in!!
like the TD30 jackaroo needs the softtech 10W30 and if you put anything else in it, it just dies and won't start again!! all hydr. taps need to come out which is a big $$$ job!
so be carefull what you put in!!
Rogue
nissan gu patrol
AAAHHHH!!
It runs alright so far ;).
So whats the difference between Dino and the other one? And why would the Dino not be suitable?
I use mobil fully synthetic 5w 50 for the ZD30 CRD, it shuts it up in the mornings and its great for the long hot hauls towing the boat.................my 2c
Currently in PAD rehab
i used delo400 15W40 in my last service after doing alot of research on here..
So far the truck is running well, power is good (probably the same) and the amount of blowby is alot less in my provent. I was running Penrite 5W40 before..
Rogue
nissan gu patrol
Discussion Starter · #12 ·
Well I drove to Mildura today (500km) car was under powered and used more fuel than normal. About 200k into it we could smell burning oil.
It turns out the oil thinned so much it was weeping out the seal of the oil filter straight onto the exhaust.
I have just finished changing the oil and filter again.
I won't be making that mistake again!!!
If I were you I would be draining the oil ASAP and refilling with Magnetec Diesel. The oil filter will still be ok so you will only be up for new oil. It's not worth the risk. The ZD30 is very particular about the oil it runs. Ive run Magnetec for the last 90,000 km.
Rogue
nissan gu patrol
Discussion Starter · #14 ·
Yeah I just replaced the oil with Magnetec (not the diesel stuff) and did the filter again just because I could. We'll see how it goes tomorrow
Have a look at whities post 'oils aint oils'. Everything you need to know about chosing an oil for a ZD30 is there.
Nissan Patrol Y-61
The first digit (15w-30) 15w says only that the oil will not be thick in the cold, but you do not have a cold you can pour this oil, it is in Russia we need oil 5-30 or 0-30 (this is where the oil goes freezing to -40)
read here
Car Bibles : The Engine Oil Bible
This site is much better, but it is in Russian through an interpreter, try your computer
http://avtomaslo.info/vyazkost-masla/index.php
"It turns out the oil thinned so much it was weeping out the seal of the oil filter straight onto the exhaust.
I have just finished changing the oil and filter again."
That sounds more like they didn't tighten the filter properly........................
Go Hard or Go Home
X2, agreed.
Rogue
nissan gu patrol
Discussion Starter · #19 ·
ZD30s have cartridge filters not canisters, it doesn't matter how tight it is done up it still seals the same.
And, it was me who services the car. :D
The seal wasn't pinched from what I could tell and the oil just left he slightest film on the dip stick when I pulled it out when the engine was warm. That's why I assumed it thinned too much when hot.
1 - 20 of 24 Posts
