I can't seem to work out where to look to find the answer.
I need to know if it matters that the hose from rocket cover to the can is 12mm but coming out of the can to the air intake is only 10mm?
Thanks in advance
As long as its atleast the same size as factory it should be right
Sorry I should say, from rocker is standard but for can to in take is only 10mm id?
