1 - 10 of 10 Posts
nissan patrol ST 30TD GU
Hi,
I have given up replacing batteries in my key fob as they only last 2 weeks and when it does work you have to be a metre away from the car before the door opens!!! I have bought a new central locking control box with key fobs from Jaycar to replace the Nissan unit.
Does anyone know where the original central locking controller is and the wire colours which control the door solenoids?
This is a 2001 GU ST wagon diesel. Any info much appreciated
Thanks
Dan
Hi,
Sorry to take so long to check out your suggestion. I dont want to replace all of the door solenoids as they work fine. I only want to replace the controller so my new remotes work.
To sum up I want is all of the door solenoids and wiring to remain.
I need to know where the controller is located and the wiring colours for the controller so it can be ripped out and replaced.
It sounds as though youve done the job and more.
Please help getting frustrated now with it just sitting on my desk!Thanks
Dan
Discussion Starter · #7 · (Edited)
Wire colours-function??
Hi,
I have found the control unit where you said it would be.I have had a bit a test on the cables but can't work it out!!!
I have 12 cores on the plug
Black/silver (-12v)
Blue 1.5mm
White/Red 1.5mm (+12v)
Green/yellow
Green/Red
Black /red
Black/yellow
Black/red
Blue/white (+12v when doors locked)
Brown
Blue
Red/Black.
This is as far as I can get.Any help on what the other colours do??
Thanks
Dan
1 - 10 of 10 Posts
