1 - 5 of 5 Posts
G'day guys,
I'm just wondering what the part is called that contains the motor to lock the door as I need to buy a new one for my LHR door. I think the teeth or something may be stripped as when i lock the door or unlock it, it just makes noise.
Cheers blokes!
Mitch!
G'day guys,
Cheers blokes!
Mitch!
It will be the plastic arm that's broken.
It happened on mine too.
I think it's an 'actuator' but could be wrong.
Yeah I thought it was an actuator, I've pulled it out already and the arms fine so i'll open it up and see if its the gear. Do you have any idea where I can buy the whole thing from.
Thanks for the fast reply mate!
look at jaycar .. they do door lock actuators that some have used to install central locking by adding an actuator to the drivers side...plus other elctronics.. so unless they are radically different then that might be an option... do a search on Jaycar for door actuator I think
Piers
1 - 5 of 5 Posts
