Hi All
I would like to ask: what is the consequences if i changed my y62 rims size from 18 inches to 20 inches ?
Is there any effects on gearbox, differentials or kilometers gages ?
If there will be negative impact how can i avoid it, is there anything I have to do in computer settings to consider the changes on rims size ?
Thanks
LED ZEPPELIN
1995 GQ TD42 NA
It all depends on your tyres. If you use a lower profile tyre you can end up with the same overall gearing. There are online calculators to help you work this stuff out.
If a Toyota can go 26", so can you: :D
Or a Jeep with 35":
