I get a bit of ~90km jitters. It's not wheel balance, bearings are good, all steering ball joints seem good, damper is probably stuffed, but that's probably not it either. If I set wheel alignment by string (1mm toe in) then the jitters go away for a week or two, then come back. Yes - I paid dearly for a professional wheel alignment, where they charged a premium because it was a 4WD, and it was exactly the same as when I do it myself - a temporary fix. Later I find out that all they did was adjust toe-in, which is easy to do yourself.
So I suppose it's the panhard bushes which I guess are 22 years old. Is there some way to check these on the truck?
