1 - 2 of 2 Posts
Dear All,
I have 2010 GU 3.0 CRD manual. When I take off I get a two clicks from the rear of the car, one from each side(left and right). Once I am moving then no more noise. If I reverse the car then I get the same noise. The vehicle has made this noise almost since new. The suspension is stock.
Nissan have had two goes at trying to find the source with no luck to date.
Any Suggestions.
Thanks
Gus
Dear All,
Any Suggestions.
Thanks
Gus
Does it only happen after you change direction? (ie. clicks when going forward after reversing, or reversing after going forward).
I had a little Toyota that did this from new. It was some slack in the brake calipers and the pads could move slightly back and forward. Quite harmless in that case.
1 - 2 of 2 Posts
