GU TD4.2t
I was away camping for a week and started to loose clutch at the pedal. It would pick up just off the floor. Clutch kit in it is relatively new. New master and slave. 3/4” slave bore.
This happened two years ago. Car has been sitting in the paddock since. I start and the clutch is no worse. No leaking at the slave.
I bleed the hydraulics and its good for 1/2 a day. It does not get any worse than picking up just off the floor.
Fork activating pin is not loose. Fork travel at the slave is 20mm minimum.
What do you reckon guys?
514388
Discussion Starter · #2 ·
GU TD4.2t
