How much free travel does the pedal have? should be no more than 1-3 mm...
There are 2 adjustments, one for pedal height, and one for free travel..
I suspect that your pedal free travel may be more than spec, so you'll need to adjust the push-rod length to bring the free travel within spec, and this should move the engagement point away from the floor...
To adjust, loosen the lock-nut at the clevis (where it attaches to the pedal lever), and turn the (threaded) push-rod to achieve the desired result :)
It's behind the pedal lever (up near the pivot), and you'll need to be a contortionist to get at it ;)
Try that & see how ya go......
