1 - 7 of 7 Posts
Sydoforumsuperfan :)
nissan gu patrol
Few weeks ago my clutch starting slipping so I bought a new 4terrain clutch which I haven't fitted as yet because the clutch became good again. Went out for a 4b yesterday and clutch starting slipping again. Then I realised on both occasions it was after going through water. Is there anything to check where water is getting to I presume the bellhousing ?
nissan patrol gr
Mate, install the new clutch, 4terrain made its stuff very well and for get clutch troubles for a long time.
nissan gu patrol
Yep definitely going to fit the 4terrain but would like to resolve this water problem at the same time. No point letting water in on new clutch hey
Nissan Safari
you need a plug for the drain hole. Also after crossing, double clutch a few times revving motor in between, will flick water off plate.
nissan gu patrol
Discussion Starter #7
Cheers. Clutch fork rubber all good. The only opening is about 5mm x 5mm square ?
1 - 7 of 7 Posts
