1 - 2 of 2 Posts
hi guy's i have a problem with my clutch when hot when iam at 300 rpm and my pyro is at
450 deg when changing down my clutch becomes hard to depress i thought it may be heat
transfer to my slave cylinder i have sence rapped my exhaust with heat wrap i have also checked my vacume ? has this happened to any of you guy's if so how did you fix it
cheers in advance dingo
Hey mate , in my maverick shorty it would always be harder to change from 4th to 5th. I had a mate tinker with it and apparently was the pressure the clutch booster was making.. which was on d/s firewall.. Don't know if this helps.
1 - 2 of 2 Posts
