can anyone tell me if this welder is ok for a general handyman type use, I know it says it is for general use.I am buying for my son who will only be using it as a hobby type thing as he is more an academic that a hands on but wants to learn.
cheers.
larger image
Cigweld Transmig 175I 240V Mig/Tig/Arc Inverter
AUD$1,049.00
Contact Us
NEW PRODUCT
The CIGWELD TRANSMIG 175i is a self contained single phase multi process welding inverter that is capable of performing GMAW/FCAW (Mig), MMAW (Stick) and GTAW (Lift TIG) welding processes. The unit is equiped with an integrated wire feed unit, voltage reduction device (VRD applicable in stick mode only), digital voltage and amperage meters, and a host of other features in order to satisfy the broad operating needs of the modern welding professional.
Features
Multi process capabilities: MIG, Stick and DC Lift TIG
Standards compliant VRD
VRD ON/OFF Indicator Lights
Digital voltage and amperage meters with preview
Multifunction Control- Infinitely Variable Voltage, Down Slope & Arc Force
Infinitely Variable Inductance Control
Push Button Trigger Mode Control (MIG and TIG Mode only)
Push Button Process Selection Control
Digital Voltage Meter
Thermal Overload Indicator
Excellent operator appeal
Processes: MIG (GMAW/FCAW), Stick (MMAW), Lift TIG (GTAW)
Supply Voltage: 240 volt AC +/15%, 50/60Hz (15A plug)
Current Range: 10 - 175 amps
Duty Cycle: MIG(GMAW/FCAW):25% @175A,22.8V(40C,10mins,)
Stick(MMAW):20%@175A, 27.0V(40C,10mins),
TIG(GTAW):25% @ 175A, 17.0V(40C, 10mins)
Recommended Generator: 9 kVA for maximum welding current
Weight Plant (packed): 23.0kg
Dimensions Plant: 460mm(H) x 320mm(W) x 590mm(D)
Plant Contents: Transmig 175i inverter power source, Tweco Prof MIG torch, Comet Prof Argon Regulator /Flow meter, Feed Rolls: 0.6/0.8mm - V groove(fitted), 1.0/1.2mm u groove; 0.8/0.9mm v knurled, Contact tips:0.8mm(fitted), 0.6mm;0.9mm,1.0mm, Electrode holder 4m lead, Shielding gas hose assembly, shoulder strap, product bag, operating manual.
Applications
Maintenance workshop, onsite tradesperson, light industrial and rural repairs
Model: W1005175
Manufactured by: Cigweld
cheers.
larger image
AUD$1,049.00
Contact Us
NEW PRODUCT
Features
Applications
Model: W1005175
