1 - 14 of 14 Posts
These compact dropboxes are the smallest dropbox on the market.
There is no cutting or grinding at all & are fully bolt on. :)
The dropbox also pushes the front diff forward 9mm so there is more room for bigger tyres.
Fitting instructions included & takes approx 2/3 hours :cool:
24hour phone assist is also available if you get into trouble :headwall:
$395 per set - postage $20
drop boxes
just brought a pair of these drop boxes they are great. easy to fit, and john is great to deal with!! thanks alot and look forward to dealing with u again
hey mate with these do ya just pull the radius arm out and bolt these on in there place there install these in to the lower spot?
and for a 3in to maybe 4in lift and using these boxs am i amble to keep my standard arms and bushes or will i need new ones to suit?
Yes mate.
Just remove the radius arms & fit the drop boxes.
Drop boxes come with fitting instructions
You keep the STD bushes
You can not run the front sway bar offroad.
Awesome stuff, had a problem with the truck wondering over the road, took it to Zordo found out the caster kit in there was all crapped out, took a lot of work to get them out, put std ones back in and put the drop boxes on, these are awesome, fixed the problem drives like a dream.
Great work and as always he really knows his stuff.
nissan gu
these look great almost factory looking so no getting picked on by the boys in blue
removed question
Reactions: theratler
had a set of these on since they were designed, have bashed them and put them throigh the ringer. Still holding up and going strong... had other brands, they were not as good.
1 - 14 of 14 Posts
