1 - 8 of 8 Posts
I have a 1990 maverick and I have a heating issue. Every time I start my car the temp gauge runs all the way up past 3/4 and once I start driving it goes down. I replaced the radiator, temp stayed good for a while then starts doing it again. I replace thermostat and water pump temp stays good for a while then starts doing it again, I replace the clutch and fan the temp runs good for a while aND now it's starting to do it again . . . Wtf
Every dog has his day
Um... if it does it when you first start the car from cold then pretty obviously it’s not the temp, it’s the guage or sender.
And also when I pull up at a drive through and wait too long it does it as well
Yeah I might have to cause I had the temp go all the way up so I checked under bonnet and it didn't feel hot, the coolant was cold and it was supposedly at the at the H
I recently pulled and cleaned up the coolant temperature sensor and gave the connections a spray with contact and it appears to have improved the reading i’m getting from it.
1 - 8 of 8 Posts
