41 - 54 of 54 Posts
GUII ZD30DI Wgn
Discussion Starter #41
In recent days testing, I will not be using RMI-25 in the foreseeable future. I'm not sure what has changed but it is not performing as previous.
Now currently on the quest for a suitable replacement.......
Would be interested in a more detailed reason why.
Why do they say it can be used as emergency drinking water but then when you read the SDS it says do not swallow and lists all the first aid for ingestion and skin contact. They don't actually list what the ingredients/chemical are just that it's a propriety mix of Xanthene.
Interesting that it didn't work out for you @plumma, what are you comparing it to previously some kind of glycol coolant?
GUII ZD30DI Wgn
Discussion Starter #43
I must have missed something, where was this said?
In my screenshot I just posted straight from their website
Edit- just noticed that it was on a resellers website not the actual manufactures. But it definitely says non toxic on the website but the SDS doesn't suggest this to who knows
GUII ZD30DI Wgn
Discussion Starter #45
OK, got it.
No idea why. Damned if I'd even think of drinking coolant.
Interested to hear about what way it is not performing. From talking to the guy from CEM the supplier of the RMI25, one of the things he reiterated was that it is an active cleaning ingredient that is used up in the chemical process of converting rust scale into a less harmful ferric-phosphate compound that is then in the water rather than coating the block and reducing heat transfer. That means as the stuff cleans the block, the water will change colour, then you need to flush it out fill with clean water and add more RMI25. It should continue to keep the surfaces clean and not change the water colour for a longer period next time (obviously that depends on how dirty, corroded the motor was to start).
Super Moderator
What was the difference in performance from before RMI-25
My td42 has had nothing but RMI-25 for the last 170k. I have used this is more than 1 vehicle as well.
I was a big advocate for RMI-25.
On the weekend while testing, we lifted the thermostat housing.
The system is covered in a brown slime that is greasy to touch.
In that past 12 months I've dropped the coolant over 10 times.
Every time re-dosing with RMI.
This weekend will be a system flush and then radiator removal for cleaning.
GUII ZD30DI Wgn
Discussion Starter #50
Will be interested in further reports after radiator removal and clean out and check of the core, I was going to go to this stuff after I fix my little leak peranently during which I'll drain and flush.
SUI GENERIS UTE
GQ Ute 1990 Silvertop
Never been a fan of penrite diesel oil but their other products aimed at the racing area seem top quality. They do make a racing coolant "10Tenths" Coolant inhibitor NO GLYCOL.
10 TENTHS RACE COOLANT INHIBITOR (CONCENTRATE) | Penrite Oil
The RMI-25 is a good product, and has been around for many years with proven results. Sometimes when the mixing is done in manufacturing it gets stuffed up but thats not the products fault, human error. If you doubt the quality of RMI-25 then there is the penrite product and probably just as good.
Plumma might test this product for us in the process.
GUII ZD30DI Wgn
Discussion Starter #52
I mention that 10 10ths in the first post and put the data sheet in post 19 (along with other data sheets), says it is OK for road use, but it is expensive.
I saw a Caterpillar coolant that ticks the boxes.....
Except it close to $1000 dollars for 20lts.
SUI GENERIS UTE
Its less than $30 to do a TD42. RMI-25 for $35 does two coolant changes.
I am familiar with the CAT product i am not a fan way to much checking Ph values to make sure its right if its not then your Alloy radiator melts.
41 - 54 of 54 Posts
