blocked the egr on my 2007 crd at the weekend bought the plate from aus4wd in Bayswater I drilled a 3mm hole in it and fitted it in about an hour, the interesting part of it is the lower egts, by about 50deg, the boost pressure seems about the same, I did not have any fault codes come up and it is running very well, I wondered if any one else has experienced lower egts after egr blocking.
