If your referring to the 1/8BSPF DV6 then that is pretty much a generic description they would recognise.Hi All
Am getting one from Southcotts, if i was to give them the part number would that be ok or do i need another part number for them?
THAT is an absolute PEARL!!OK I just searched the Dependable Distributers Web site and they must of had a few guys calling and asking cause I found pack
Nissan Patrol Turbo Boost Adjust Kit.
Stock Code: 201139
Comes complete with all you will need to rectify the problem of Boost Pressure from the Turbo on the Nissan Patrol.
Price: $85.00 ex GST
I will call them this week and order mine this just makes it to easy to get what I need (I have had the dawes valve just sitting there for a while now). I don't work for them or have any vested interest and live in Brisbane but this is looking good
Hope it helps others
Mmmm, me thinks Chaz and I should be getting royalties :lol:OK I just searched the Dependable Distributers Web site and they must of had a few guys calling and asking cause I found pack
Stock Code: 201139
X2, you guys helped me imensly when I was putting mine in.Mmmm, me thinks Chaz and I should be getting royalties :lol:
Great kit but needs longer vacuum hose and two "T" pieces for breaking into the VNT and bleed line (at the filter) if you want to install it in the cabin.
:cheers:
Ta Dan!X2, you guys helped me imensly when I was putting mine in.
PS. I think the single dawes/needle setup will suffice for 99.9% of Patrol owners.
The components used in the dual dawes system can be used to set up a dual needle valve system, obviously swapping the second dawes for a second needle valve.3Bar Racing will sell you the bits required for a dual TDI boost controler (Dawes Valve) setup.
Absolutely, but you may need to readjust the dawes as well when you do the EGR due to the changed spool up rate. It is always better to make one change at a time, to me you come out of the exercise better educated that way.The components used in the dual dawes system can be used to set up a dual needle valve system, obviously swapping the second dawes for a second needle valve.
Guido mentioned existing posts. This is the one on the dual needle system:http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/single-dawes-valve-dual-needle-setup-42841/
I am going to go single dawes first, perfect that and then try a dual needle system.
I have a few questions. I am blocking the egr as well. Can you set up the single needle & dawes, before blocking the EGR and run it for a while to iron out the settings? Then after blocking the EGR, make any final adjustments on the needle.
Grogey.
I recently changed the size of the boost line to the dawes, still 3mm to the gauge but stepped it to 6mm to the dawes, after doing this I had to readjust the dawes, small things can make a difference.
