1 - 3 of 3 Posts
I will start by saying that I have a inline filter between sub tank and main tank and I changed the filter today and cut it open and found it the be full of crap. I fitted another inline filter between the two tanks and it now transfers over much quicker.
In light of this I will be changing the main fuel filter aswell.
The Q I have is would it be worth puting another inline filter just before or after the main fuel filter ??????????
its a GQ TD42
I have an inline one just before the main filter in mine, that I change every 1000k's or so.. the reason being though that the long range tank had a fraction of surface rust on the inside when installed, and it is constantly loosing little fragments.. saves the main one blocking prematurely, as they are a lot more expensive..
To answer you question won't do any harm, and they can be changed easily..
Thanks boys the flow was one of the issues I was thinking of
I put a fleet gaurd metal inline filter with 3/8 inlet/outlet I should of kept that sucker for before my main filter I will get another one
1 - 3 of 3 Posts
