141 - 152 of 152 Posts
I learn't a valuable lesson today. The studs in the head that fasten the heater pipes are tapped all the way through to the coolant gallery so I had a slow leak from the 2 studs. I disassembled the heater piping removed the studs cleaned all the threads, both in the head and the studs then applied Permatex Aviation Form a Gasket to seal it all off.
Rookie mistake
Lol. Easy to miss that. Aviation form a gasket is great stuff. Have gone through many many bottles over the years.
2016 CRD wagon
Rookie mistake 🤪
Haha, who would've guessed??!!
Seriously though, job well done. How sweet was the sound of it ticking over in the garage?🥳
You'll be excited every time you drive it now after getting to know it so intimately and with the couple of performance mods
Super Moderator
Discussion Starter #143
Yeah I love the stuff.
Super Moderator
Discussion Starter #144
Thanks Trev. I can’t wait to put some serious k’s on it.
Super Moderator
Discussion Starter #145
Rookie mistake 🤪
After letting it cure for 24 hours I filled the coolant up again and again it leaked :(
So I'm thinking that I'll remove the nut and stud and fit a bolt with a sealant. The thought is that the coolant cannot travel along the thread and out the head of bolt.
@geeyoutoo & @skegbudley what are your thoughts?
Is it actually leaking along the thread and out the end of the nut?
I didn't seal mine at all, I put some aviation stuff on the gasket only around the hole, and not anywhere near the studs.
I will have to check!!!
Super Moderator
Discussion Starter #148
Yeah I was watching the fluid form then dribble down then drip onto the block.
Super Moderator
Discussion Starter #149
Well I found the problem. I disassembled the heater pipes again today and while the studs were still in I gave them a wiggle and both had movement. The studs were supplied with the head so I grabbed a couple of M8 bolts then tried them in the head and same thing. I tried an m10 and it was far too big. My conclusion is the hole was drilled slightly oversized and then tapped.
I'm not about to remove the head just for this problem so after a bit of research found it was common across different manufactures of engines and for people to use high temp RTV to seal leaking bolts the enter the coolant channels. I had to removed the gasket anyway so I cleaned all surfaces and bolts and threads then assembled it using the high temp RTV with extreme caution not to restrict the flow of coolant by getting it inside.
The bead of RTV in the picture is only about a 1mm, its just a close up shot.
516637
What brand head was it?
Sent from my SM-G960F using Tapatalk
