1 - 2 of 2 Posts
nissan gq ute
whats involved in gettin my pump to pump more fule, is it simply a replacement pump or can they be modded. and what sorta coin is it worth,
and is it worth it.
all info appreciated cheers
it can be adjusted, up to a point. it all depends on your intercooling and turbo for how far you go with it and if adjustment alone is enough.
if you want it to go really fast (well, for a diesel anyway) it will cost you about $2500 for a performance pump rebuild. then you'll probably need to add an electric lift pump for another $200 or so to help get the fuel from the tank to the pump.
1 - 2 of 2 Posts
