1 - 15 of 15 Posts
Nissan patrol gu
I need to replace rear rotors on my 2005 4.2td wagon and while I’m at it I’ll replace the front.
My question is -
Are there good and bad rotors, are they all the same - any recommendations appreciated
shakey55 they're not all the same. Like everything in the auto world there are cheap copies. I would suggest genuine, RDA or DBA. Be careful of the so called "high performance" slotted and drilled cheapos on eBay.
GUII ZD30DI Wgn
My question is -
After much research I went for RDA slotted and dimpled and it was the best thing I ever did for brakes, been on for a few years now with absolutely no regrets.
GUII ZD30DI Wgn
Ross, what pads are you using again...? Genuine Nissan 4.8's ?
Yes, still fantastic stopping power and no crap build up on the rims, love them.
Nissan patrol GU
X2 ,RDA slotted and dimples with genuine 4.8 pads
DBA T2 rotors and matching XP pads front and rear. Tried a few different pads and this is the best so far, EBCs are next pads to try.(y)
My question is -
I replaced mine F/Rear. with Bendix slotted and matching pads.
Towing a 3+ ton caravan, Tinny on roof. av weight over scales around 6.2 ton.
They smooth as, and pull up evenly every time.
Nissan patrol gu
Discussion Starter #9
What did the full set of Bendix cost you
Sorry. I can't remember now. was about 8 yrs ago. Pre D-Max.
I do remember the Safari Solid Flywheel and H/D Clutch ASSY cost me $2,650
supply and install.
Was VERY happy with both while I had veh.
Current owner still is and he uses O.Road.
Nissan patrol gu
Discussion Starter #11
What are the experts thoughts on these rotors and brake pads
GUII ZD30DI Wgn
No experts around at the moment, assuming discs are RDA as well, should be fine.
Nissan patrol gu
Discussion Starter #13
Yes RDA Rotors
Description
BRAND NEW - GENUINE RDA - FULL SET DIMPLED & SLOTTED FRONT & REAR DISC BRAKE ROTORS + RDA EXTREME BRAKE PADS
Have had them on my patrol for 4 yrs now and still on the same pads. Haven't had any issues with them and patrol pulls up ok for a heavy thing.
1 - 15 of 15 Posts
