1 - 7 of 7 Posts
GUII ZD30DI Wgn
Fixed title. There are quite a few threads on overheating and the 4.2, I'm sure someone will chime in but you could do a search as well.
GUII ZD30DI Wgn
Just to add, there are degrees of overheating, some will result in damage, others are survivable, what is your description of your overheating event?
How hot,how long,loss of coolant,loss of oil,?? does it run now,and signs of a problem ? Was it topped up hot ?
Cheers,G.
Noticed it straight away butt had to nurse it for about 10km ..it was pressurizing and pumping water out the over flow .. we topped it up while it was running didn't shut it down butt wen topping up after about 5l it started to spout water out of the radiator top up spout ... so I'm guessing the head gasket has blown ...also I'm thinking the thermostat has been takin out ..... going to pull the head off next couple of days cheers
GUII ZD30DI Wgn
Thanks for explanation, 5L is a fair whack, let us know how you get on mate.
1 - 7 of 7 Posts
