As the title, does a GU4 come without flares or not? Looking at bullbar to suit a GU4 st. If anyone would have the correct part number to suit this ST could you post it up.
Yes, I,m pretty sure the DX does not come with flairs.
GU4 Genuine Nissan Steel Bulbar:
F2210-VD010AU WIDE WHEEL
F2210-VD210AU STANDARD WHEEL.
Any Nissan dealer can confirm this.
Ironically Nissan makes the same plate with both part no. shown and fixes this to both types. To be certain of the correct part check inside the passenger side of the bull bar. On the down tube in side the main part of the bar there should be another small rectangular plate spot welded to the tube with the true part number stamped on it. It may be hard to read as it will be painted over.
Grogey
