Hey guys just chasing some or your opions and if this sounds about right to you guys..
I own a 05 model GU DX TD42 intercooled ute. It has 35" tyres, 3" lift, 3"exhaust and a HPD Intercooler that fits on to the original brackets for the standard one. I have also wound the boost up to 15 PSI everything else is standard. I use it to drive to work which is roughly 470kms one way, I sit on 100 - 110 kph. I fill up each time i leave home and when i leave work and roughly put in 83ltrs each time and only seem to be getting 450-500km out of the main tank and there is no weight on the ute just my tool box on the back with my bag in it.. is that about right for fuel usage on ?? When sitting on 100kph it is also on full boost even on a flat secton of road so i dont know if this is normal either.. and the egts never go above 400, they sit on about 350 when crusing at 100kph and only climb to round 400 if i am going up a hill or holding my foot to the floor over taking.
so just some advice if this all sounds about right to you guys.
cheers Scott
cheers Scott
