1 - 9 of 9 Posts
Patrol 2.8 TD
Just got my truck back from ARB. I had 4 nitro charger sports shocks fitted and and ome damper.
Drives like a dream and my steering wobble is gone.
The guy went on to say this:
Bob, your truck was lifted before. Who ever owned it before you lifted it then put the old springs back when he sold it. I asked how he knew and he said, whoever owned it had a castor kit installed.
It changes the angle of your diff (to which im like ????)
He goes on to say, my damper was totally cactus (which i knew) and to totally correct all steering issues he said i need to either remove the castor kit or install 2 inch lift coils.
Now before people jump the gun here, he wasn't out for a sale as Ive already told him, i want king springs, they only stock ome springs and he knew i was going elsewhere to get the coils done.
So what does he said make sense?
I was getting the coils done anyway, and i wasn't going to lift it, but if the castors are already there, hey why not.
Thoughts anyone?
As long as your shocks are long enough, then go for it. Did he say how many degrees the castor correction was? Is it bushes only or is it castor plates?
Patrol 2.8 TD
He didn't say, he just said i might as well get a 2' lift seeing as the castors are already in there.
Nissan Patrol GQ GU
If it has nylon caster correction bushes they will shag out eventually. He is right that the caster "correction" will be wrong if you have standard height springs as there is nothing to "Correct". you are likely to have an under steer problem i reckon, so a little slow or heavy in the steering with a return to centre bias.
You have 2 options
Option 1. put 2" springs in it.. Is there a reason why you were not planning on doing this?
Option 2. Take out the caster correction bushes and replace with good Rubber ones that will see you do 300K+ and run the standard height springs in a King as planned.
You should not DO NOTHING though.
Patrol 2.8 TD
oh bugger that, i don't go near suspension.
Why didn't i want a lift? I just like the ride height how it is now, although Ive been told it's a lot smoother with my head 2 inches closer to god. Also Ive recently learned i cant ram 35 inches of rubber under the guards without a 2' lift.
So 2' it is.
Thanks for info guvner
So 2' it is.
Tonka, as per the last offer mate give me a yell. I just did mine with 2". Piece of piss.
Troy
Well you said on the 'tell him he's dreaming thread' that you prefer to buy one standard..........he almost put it back to standard ;)
Patrol 2.8 TD
Discussion Starter · #9 · (Edited)
cox :)
I could take it or leave it, not that fussed fellas.
Troy, good luck this weekend with the chip matey
1 - 9 of 9 Posts
