1 - 14 of 14 Posts
06 Td42ti cab chassis
Any one using the new kings 9" Domminator xtreme driving lights and what are your thoughts?
How do they compare to the earlier 9" kings lights?
All these cheap LED lights use way too much power for my liking. Take a big chunk of your alternators output. About 32 amps from memory, at 12v, not 14v or whatever some of them use. That is a lot. My alternator is only 90 amps!!!
As a comparison, my HID's draw 9.2 amps at 12v.
4x4nissan
Disagree mate, my kings 40 inch light bar draws about 9.2amps
1 lux at 1,380 m is very impresive..Even more so for $170.00..
Im surprised someone isnt using them :unsure:
2018 Mazda BT50 Dual cab
I have the old ones with the Osram led’s. I’m happy with them, could do with a bit more distance but 90% happy
That’s better than my ARB intensity’s. They don’t shoot anywhere near that far.
I have been thinking about putting my Hella 4000 converted Hid’s on. As I still miss the extra distance.
Discussion Starter #8
Yes..I had a set of Narva bull lamps on my old wagon that I converted to hid and they shone a mile..
Atm I Have the older 9" kings lights but I was just chasing a bit more distance..
Best combo I had on the Patrol was a light bar and the genuine Nissan spotties with individual switches
Discussion Starter #10
Atm im running a 40" light bar on my load bar so I have plenty of spread either side but just after a bit more distance out yonder..
A bloke I work with has a set like yours YB and he thinks they are the pussy cats meow and the new ones are ment to be better again..
P = V x I, is the calculation used to work out such things.
These lights appear to be upgraded from when I Iast looked at them, and are now using new LED's which use less power. So that is good, but they do not specify the wattage of them which is dodgy.
Previously they used 5 watt LED's, these one's may be 3 watt. If that is the case, not as good as HID, but not as bad as the old ones.
According to the specs on the website it will be 19 amps at 12v. Better than 32 amps for the old ones for sure.
2016 CRD wagon
I had the earlier 9" kings LEDs. They were ok and pretty good bang for buck.
I upgraded to the new ones about a year ago. They are considerably brighter with greater distance and spread.
Draw backs I see with these lights is they are so damn bright, the reflection from road signs etc is almost unbearable. If your driving is mostly country this wont be an issue.
The other issue is when you dip your lights it's really hard to see!
From memory they have quite a high Kelvin rating, a bit higher than ideal for road driving, with reflective road signs etc. This would be a factor.
1 - 14 of 14 Posts
