I have just had my rear barn doors repaired after a minor rear-ending by a truck.
http://www.patrol4x4.com/forum/general-discussion-18/just-been-rearended-mazda-truck-169962/
It has taken four months to get repaired as I was waiting and waiting and waiting on a new Kaymar rear bar.
I have a new big barn door and the other door re-painted. But the panel beater just stuck the old plastic sheet inner back under the door trim, it is torn and clearly needing replacing to keep dust and moisture out. I have some plastic sheet, the panel beater suggested mastic but that melts in the heat and is sticky crap. He said they often just use spray glue contact adhesive.
So a question to the paint and interior trim Gurus.
What is that sticky black stuff used to hold the door plastic sheet under the door trim panels.
The stuff is not silicone or Sika sealer as it does not cure but it stays tacky, it can be peeled off and re stuck. It stays stretchy, it never seems to harden or dry, it can be peeled off and does not leave a sticky black crappy mess like mastic.
So who knows what it is and where to get it.
