1 - 7 of 7 Posts
Hi all,
I have one of those double din android head units, and was wondering which is the prefered fitting kit to get.
Do I just go for a universal one?
Its going in a GU6 ST ute.
Ralph
NISSAN GU PATROL
Hi Mate.
If you can cut and solder you don't need anything, otherwise one of those iso to nissan harness. Im not sure about the antenna, maybe one of those diversity to normal antenna adapter.
Hi jimako
thanks for the quick reply
the wiring is not the issue, it's the actual head unit.
how does it "attach" to the dash.
The unit I'm about to put into my 99 uses the original double din mounting plates that screw onto the sides of the original head unit. It''s a piece of cake to fit - only thing to watch for is not to use long screws into the new unit - use the original short ones.
NISSAN GU PATROL
Yeah what Burra boy said,
But i wouldn't know about the GU6, im guessing the same.
thanks guys, I'll keep you posted on how it goes.
Discussion Starter #7
Hi guys,
Just installed the new head unit. Got to say, it went in with no problems at all, literally a 5 min job.
Used the Aeropro ISO harness adapter.
Now to hook up the rear camera and TPMS.
Ralph
1 - 7 of 7 Posts
