1 - 3 of 3 Posts
Rubber around my drag link on drivers side is worn and falling away.. Can i buy new rubber or should i buy a new end
Unless you have an aftermarket drag link already (with threaded tie rod ends) you will have to replace the whole drag link - can't replace just the ends. Check the vendors section on the forum for new ones (offroad runner have some specials). You could potentially replace the rubber boot, but chances are it's original and the tie rod end will be well stuffed. Just replaced mine and wasn't too difficult (and you get to use hammers :grin:
1 - 3 of 3 Posts
