1 - 5 of 5 Posts
are all gu drag links the same ? will 1999 wagon ones fit 1999 coil cab ?
I'm not aware of any changes to drag kinks throughout the range, if I'm wrong someone will tell me.
Utes and wagons had a few differences with the panhard rod bushing size but I'm pretty sure geeyoutoo is right the drag link on all GU have the same taper fitting on the tie rod ends. Only GQ had a different end.
1 - 5 of 5 Posts
