Tried some of this stuff- someone might be interested in the results.
Essentially its just a layer of thick foil and about 4mm of soft sticky rubber.
Your meant to put it inside the doors as well-would be too much work so I just used the spray on sound deadener in the cavities.
Then stick this chit on the inside skin
floor was lots more work than it looked;
Chance to tidy up the wiring...
It's got to be stuck fast everywhere or the panel will still drum.
Started out being real careful...by the end I just put it roughly where required then attacked with a rubber mallet= same result
Overall I think it was worth it- I can hear the handsfree on the freeway now and generally have the radio a little lower. Hard to quantify as I started with a really loud truck to start with.
I put two layers over the transmission tunnel- very noticable drop in temperature on the freeway.
