1 - 1 of 1 Posts
i have a 2001 gu zd30. it started to have trouble starting
the starter solinoid would click but only some times turn the starter motor or would stick on after i release the key.i also think the solinoid was shorting out. So i replaced the solinoid only
but now when i start the car the new solinoid cuts out and back in,like a loose wire would do. i have checked them and all ok.
and then i get the error light comming on with a 0301 code
after 2 trys the engine starts and runs fine
has anyone had this problem?
what can i check?
do u think the ecm is shot
1 - 1 of 1 Posts
