hi everyone
I'm chasing an ECU Pin Outs Diagram for a Nissan Patrol Gu 1999 model Y61.
Regards Ed.
issue resolved
Send me an email address and I'll send you a .pdf
Thanx Inforcer, it's all good now. Turns out Nissan use the same ecu pinouts across many vehicles in there range. We used a ECU pinout for a Nissan Skyline ECR 33 and whilst not all are the same many are. Brilliant!
Thanx for the fast response though, Respect.
If it's the same as the ZD30 and someone may be able to confirm or deny this and I'll learn something new today :).
Pinouts, ZD30 DI ECU
pin 2 Intake Air Control Valve Solenoid.
Pin 4 ECM Relay (Self Shut Off)
Pin 5 Tachometer
Pin 11 Exhaust Gas Control solenoid
Pin 14 Engine Cooling Fan relay
Pin 15 Air conditioning Relay
Pin 16 Glow Plug Indicator Lamp
Pin 17 Brake Lamp Switch input
Pin 18 Engine Check Lamp
Pin 19 Engine Coolant Temp Sensor
Pin 20 Engine Start
Pin 21 Air Conditioner System Switching
Pin 22 Neutral Position Signal (auto)
Pin 23 Accelerator Pedal Position Sendor
Pin 24 Automatic Transmission signal #1
Pin 25 ATCP module (if fitted)
Pin 26 Verhicle Speed Signal
Pin 29 Accelerator Pedal Switch
Pin 30 Automatic transmissionm signal #3
Pin 31 Accelerator Pedal Dual Contact Switch Idle
Pin32 Accelerator Pedal Dual Contact Switch full
Pin33 Injection Pump Control Unit
Pin 35 Mass Air Flow Sensor
Pin 37 Automatic Transmission Signal #2
Pin 38 Ignition Feed
Pin 39 Main Ground
Pin 40 Injection Pump Control Unit
Pin 42 Diagnostic Connector
Pin 43 Ground
Pin 44 Crankshaft Position Sensor
Pin 45 ATCP Module if fitted
Pin 46 Charge Air Pressure Sensor
Pin 47 Crankshaft Position Sensor Ground
Pin 48 Accelerator Pedal Position Sensor Power Supply
Pin 49 Sensor Power Supply
Pin 50 Sensor Ground
Pin 51 Accelerator Pedal Position Sensor Ground
Pin 52 Injection Pump Control Ground
Pin 53 Injection Pump Control Unit
Pin 54 Swirl Control Valve Solenoid
Pin 55 Anti theft system data line
Pin 56 ECM Power Supply
Pin 58 Automatic Transmission Signal #4
Pin 59 Heat up switch
Pin 61 ECM power supply
Pin 64 Diagnostic Connector
Pin 65 Diagnostic Connector
Pin 68 Accelerator pedal position signal to auto ECM
Pin 101 Turbo charger control valve solenoid
Pin 102 Ignition Feed
Pin 103 Exhaust Gas Volume Retic Control Valve if fitted
Pin 105 Exhaust Gas Volume Retic Control Valve if fitted
Pin 106 Ground
Pin 109 Exhaust Gas Volume Retic Control Valve if fitted
Pin 111 Glow Plug Relay
Pin 112 Ground
Pin 115 Exhaust Gas Volume Retic Control Valve if fitted
Pin 116 ECM power supply
Pin 118 Ground
