Hi guys, got the ECUtalk cable and running it on my laptop, have taken a log from a short trip (20km) for all to see....you will notice that the car is running quite hot adn gets to 110 degrees climbing up the shot hole canyon rd.
Couple of questions....if i have a faulty coolant sensor wouldnt the ecu and therefore ECUtalk read high? The temp gauge on the car got to 3/4 and this has been an ongoing problem with radiator been rodded, new radiator caps, new water pump and viscous coupling, two different thermostats and not using a thermostat, but it contiues to get hot. Doesnt loose water or boil.......
OK and other question is....what do the ECutalk sensors mean and what should their readings be?
Thanks again.
PS i had to delete alot of the log to fit it on here but if you want the whole thing i can email to you.....pm me....
Thanks again.
