1 - 9 of 9 Posts
hi all .
ive done serch and still no defenent ansers.
i got my auto meter egt today .
my ? is what depth to set probe at ? i have sevral choises .
35mm / 1/4 / in middle of 2/3rds or just use clamp set up and put it in middle of exsurst ?
please help .
it is gu 3lt with 3 inch exsurst , probe will be 50mm down from turbo in exsurst .
thanks ricky
I have mine in the centre, but I doubt that it will make much difference because the exhaust gas flow will be quite turbulent just after the turbo
put it in all the way, the more probe exposed = more accurate reading imho
they measure the temp where the thermocouple junction is which is the very tip of the probe. put it halfway in.
Autos are Superior
Contact the company and ask them.
It does make a difference.
ZD30 Out - L77 In!
The sensitive part of the probe is only about 5mm from the tip. Normally we place them into the exhaust between 5 and 15mm, depending on the size of the exhaust pipe. Any further in and you will be creating unnecessary turbulence in the exhaust system.
Google EGT Probe Length and you’ll get the answer.
hi the insructions say the probe will have its tip in the middle two-therds of the exhaust stream useing clamp set up .
it dose not give deapth for weld in bung set up .
but if i use the bung setup that is welded in tip of probe will only be 35 mm in .
thanks for replys
ricky
i will put probe in bung setup and see what temps i get .
as i can always drill a hole for clamp setup .
thanks ricky
1 - 9 of 9 Posts
