Hi,
I have had a Madman EMS2 fitted with an EGT probe 50mm below the turbo for a year or so now. It a great unit and has an alarm and saves maximum reading levels.
In that time i've had 4 massive but momentary EGT spikes of approx but very close to 1034 Degrees C. the last one being last night. (1034 was yesterday)
Typical scenario:
I did add 20 litres of Shell diesel the evening before the latest episode and added the 2T as normal plus Chemtech diesel power at the normal rate, 1 to 1000. I normally do this to both full tanks every 3 to 4 months for maintenance. I will be on the look out next time as well. (this time i had a jerry can of fuel that i wanted to use up).
So i'm not desperately worried (should i be) as the spike is so fleeting. But as ever i'm interested in whats happening in my GU. I would imagine those with a dial type gauge or a gauge with alarm or no recording function would easily miss these spikes as they are over in the blink of an eye.
I have an idea that it might be something like soot getting burnt of the tip of the probe, and that might also be chemtech related but thats only a hunch.
Your thoughts,
Grogey
Typical scenario:
- Nothing in tow
- Acccelerating normally away from a stop (such as traffic lights)
- EGTs in the space of 1 second goes over my 500 Degree C alarm level setting of the alarm.
- Back the foot of the throttle and glance at the gauge.
- EGT is likely over 600 but already falling. And likely would still be falling even when maintaining throttle input.
- EGT normalise within a few seconds. The whole episode, start to finish all over in 3-4 seconds.
- When i check the max reading. Typically between 1030-1040
Your thoughts,
Grogey
