1 - 2 of 2 Posts
Hi all.
2002 GU. I've searched the archive but can't find the exact answer. We disconnected the battery to do some welding and when finished found the auto function of the drivers window no longer worked. We powered the window down and held the switch down for a count of two then did the same for the up travel. We did this several times but it didn't change anything. Are we not holding the switch down long enough? I don't want to burn out the motor. I've also heard of a reset switch on the motor but that appears to be for the anti pinch function. Any ideas would be greatly appreciated.
Discussion Starter · #2 ·
Stop lookin' everybody - we found it. :) It appears it was a dodgy pin in the plug going to the switches. Found it completely by accident (as always) and now seems to be fine.
1 - 2 of 2 Posts
