I had a electric window winder issue with my drivers side front window would not go up and down without stalling and getting a long clicking sound and,unlike a stripped cog with a fast vibrating sound
after removing the door trim and pulling motor and gearbox off I could see that there were grooves worn between the holes where the metal part engaged with the large plastic cog, I think its is a design to dis engage as part of a anti jam/overload mechanism and the previous owner must have had a stiff window or something at some time causing it to jump and dig the grooves
I then bent all of the metal tabs out with a pair of pliers so it gripped away from the grooves ,banged it back together and back on and have not had any issues since
Hope this helps someone else out there in the mav/patrol network:)
If you drive a box you get box
thats the issue i have at the moment
are you able to take a few pics to show what bits you exactly mean? i can picture it but want to be positive
good find to fix though ;)
