1 - 5 of 5 Posts
I have an issue with my patrol. When I turn the car on I have no accessories at all no wipers,radio,indicators etc. I can give it a rev and then it's fine until I turn it off again. Then same symptoms. Ive pulled every plug under bonnet and fuse box and cleaned with contact cleaner. I'm think may be the regulator in the alternator. Would that cause this???
Thanks
GHMBC #3
nissan patrol gq lwb,3"lift.
have a look at connections around fusible link
I agree fusible link or a bad connection at the fusible link.
Everything starts working once the alternator starts charging so I would say your alternator is fine.
Is the problem the same when you just switch to acc - is the radios et's comming on?
Put a volt meter across the battery - what volts do you have prior to giving the vehicle a rev?
It could be an issue with the swich / fuseabe link etc feeding the acc power that has some resitance = voltage drop. The revs are bring the volts up enough after the switch to running you acc's.
If the truck is starting ok - etc its mostly nothing to do with the alt or battery.
1 - 5 of 5 Posts
