I couldn’t give a flying fcuk what you have it haven’t found, I merely stated what is required to be there.Complete Bullshart. Have never found a bleed resistor in a motor or a metal halide or flouro fitting or a switchmode supply. Have been bitten a few times, no big deal.
Haymans are slowly driving me away as a customer. Used to be 10k a month. Sick of chasing up outrageous price increases. I can purchase the same two items on say two different days of the week and the pricing will be different?They used to look after me really well once but i changed jobs about 7 years ago and my account has become inactive. The front desk guy doesn't seem to have any control over pricing any more either so now i pay the same as everyone else![]()
I used to question everything, and once you'd bought it once that price was locked in for future purchases of the same item. But I was on contract so any cost saving was in my pocket and if it went the other way I couldn't pass it onI can purchase the same two items on say two different days of the week and the pricing will be different?
No not yet. It is easy enough to turn by hand thoughRant over have you dropped the belt off the motor yet?
My pricing is supposed to be fixed as well. All goes out the window every time a supplier to them has an increase.I used to question everything, and once you'd bought it once that price was locked in for future purchases of the same item. But I was on contract so any cost saving was in my pocket and if it went the other way I couldn't pass it on
No worries mate, so now a reliable BLEED RESISTOR has become a discharge path. On part of a circuit that can fail. I must be imagining the zaps I have had from circuits that have been de energised for a lot longer than 50 seconds.I couldn’t give a flying fcuk what you have it haven’t found, I merely stated what is required to be there.
AS3000 4.15.3.1
‘Capacitiors with values greater than 0.5uF shall be provided with a discharge path’
etc etc etc
Ok it doesn’t necessarily have to be a resistor in all circumstances, the windings of an appliance can firm a permanent discharge path for instance 4.15.3.2(a)
Up to a 650V rated cap it must be 50v or less after 60 seconds, otherwise it does not comply.
Not too many grey areas in the bible.
This really sounds like you might have some wires the wrong way on the motor start capacitor. Did you take a photo of it before removing the old one?Suggestions?
CSCR motors usually have a centrifugal switch at the arse end of the motor, it makes a click when the motor gets up to speed and disconnects the start cap which provides the extra torque. Even if yours clicks, check to see it has not gone open circuit.Ok clever people. I have replaced both caps and still no joy. At least when I replaced the white one it attempted to go.
@Haggie I've run the belt off. Motor seems to be happy moving through startup and running, then clearly moves back to start when almost stopped again.
With the belt on, if I give help turning the big pulley it will start and continue to run, but will not start on it's own. Sounds like it wants to but doesnt seem to have enough power. With the belt off neither pulley is difficult to turn by hand.
Suggestions?
Yes OB. Took a pick and referred to it when replacing it. I will check it again though🙂This really sounds like you might have some wires the wrong way on the motor start capacitor. Did you take a photo of it before removing the old one?
I understand what an open circuit is but I wouldn't know which wires to test. Any clues?CSCR motors usually have a centrifugal switch at the arse end of the motor, it makes a click when the motor gets up to speed and disconnects the start cap which provides the extra torque. Even if yours clicks, check to see it has not gone open circuit.
Too many variables to tell you what wires to check, pull the back off the motor and inspect the switch and put the meter across the terminals, and physically check its operation.Yes OB. Took a pick and referred to it when replacing it. I will check it again though🙂
I meant it is slow to start now but used to start easily before all these troubles.You said "I have replaced the white capacitor that appeared to be not right and it now runs but it doesn't start up as strong as it used to"
Yes definately hums but wont run backwards if I try to spin it in reverse.Moving on to another test > I expect it hums when you turn it on? > then starts and runs IF you help it by turning the pulley you said
I swapped the old black cap back in and made no difference. Still need to help it get started
Bugger!!! Time to kick the wheels and swear at it???
Well that's very good, something positive
I didnt replace the first cap that died a couple of years ago but I'm pretty confident I've put wiring back to where it was this time. It hasn't done a lit of work in the last couple years but was starting ok .
Meaning you didn't actually do the original swap no worries
I'm looking after a motor that we had to fit the wrong cap and it is slow to start now for about a year. Have the correct cap but never seem to find the time to fit it
Beginning to wonder if your new and old black caps are almost dead
Can you wire both caps side by side > ie double up in Parallel, like 2 x 12v batteries but still only get 12 volts?
I'm sorry, without being able to poke my fingers in there I'm at a loss
Bit like my zd30 conked out and nobody can explain what wrong with it, idles but wont rev up, like your electric motor
Might be time to take yours to a motor rewind type electrician and hand over enough $s to buy a whole new compressor lol
